replace rear spring rubber bump stop
Scoobysrt
Re: replace rear spring rubber bump stop
Post by Scoobysrt »
Ah, stop buffer, when I asked tps they said rubber spacer but couldn't give a part number now I know why lol.
lal138
Post by lal138 »
HI Doc thanks for verification those were what I fitted to my van we all know now what part we need to order if missing damaged perished or worn out Thank You for verification information Pete :D :D
PJD
Post by PJD »
Found this thread because every now and then if the suspension drops down from a speed bump or drain cover it will make a loud metallic clank like the suspension has bottomed out. Just as described here with the bump stops being missing.
The thing is when I look under the van there is one leaf spring so obviously no place for a bump stop on the second smaller leaf spring.
Am I missing something obvious?
