Abs bleeding
- janis
Abs bleeding
So had to replace abs punp today as old one start leaking. After reaserching how to bleed abs, had lots of videos and treads about using vcds. Now my vcds not offering that function. Is it because its its older 2007 van? Or is it my vcds?
- janis
Re: Abs bleeding
janis wrote:So had to replace abs punp today as old one start leaking. After reaserching how to bleed abs, had lots of videos and treads about using vcds. Now my vcds not offering that function. Is it because its its older 2007 van? Or is it my vcds?
- Javito
Re: Abs bleeding
Could it be under adaptations?
- janis
Re: Abs bleeding
I did look anywhere. I could turn the pump on in settings for outputs. But not like bleeding.
Anyway, done it in old way and started from furthest rear wheel and work my way up, took her for a drive and no issue. Brake pedal feels good.
