Acapulco Blue Caddy Maxi Life
juliang71
Re: Acapulco Blue Caddy Maxi Life
Post by juliang71 »
A long overdue post with pictures of how my Caddy Maxi has looked for probably about a year now. In no particular order.
  • Limo tints on the rear and back windows
  • Side strips redone in matt black
  • Mirror caps painted gloss black
  • MTS Technik Coilover / Lowering kit from Darkside Developments
  • Rear shackle support block kit
  • Bolt kit for twin leaf springs (Maxi)
  • Team Dynamics Pro Race LT 18" wheels in gloss black
  • Bridgestone Turanza 225/40 R18 tyres
The only issue I have, well there are two really. The rear is not setup right and I'm struggling to see why. The rear wheel is central in the arch and the hanger was set on the 2nd hole from bottom for a 60mm drop. But with any weight in the rear of the car the back of the rear tyre would foul the inside of the wheel liner? If anyone has any thoughts or ideas on how to resolve this I would really appreciate it.
At the front I can just about fit two fingers between the top of the tyre and the wing, but the rear is easily three fingers and to be honest I just don't like it. I want the rear to be a good 20-30mm lower but obviously not hit anything.
As for the second issue, that will be a post for another time now. But overall I'm really happy with how it's turning out. I've no plans to make any more changes externally I can think of. And internally the only things I really miss are having a reversing camera and folding mirrors.
Thanks.
Post by stu_b »
Looking good
The limo tint is total blackout !!
Is the sliding door sliding window standard on the life ?
Looks very user friendly
The 2/3 finger difference would be negligible once you get something in the back
A lot of hard work going in to your van
juliang71
Post by juliang71 »
Thanks, yes the sliding windows in the rear are standard on the Caddy Life & Caddy Maxi Life Mk4. It is very user friendly and I'm still amazed at just how much room you get with the Maxi.
juliang71
Post by juliang71 »
Wow, five months since I last posted! Not a very exciting post this and only got a few pictures of what I've been up to today but more to come. After I started my sound deadening and insulation on a budget I knew there was room for improvement. I only bought one roll of recycled loft insulation so went and bought another one yesterday and removed all the trim out of the rear again. I then went and filled any remaining gaps I could see / find.
And next was the passenger door as I never did this first time around. The door card is pretty easy to remove, watched a YT video on it but did manage to break a clip and a piece of bracket of the door but nothing super glue couldn't sort out. And clips are cheap as chips of AliExpress or eBay. I then just cut an access hole as can be seen and my 5mm sonic gold laminate floor underlay / come sound deadening material is in and I did manage to get some loft insulation in without fouling the window at all. Overall very happy indeed and just the drivers door to do now.
I did forget to get a picture of it all done before I taped the access hole back up but you get the idea of what I was doing. The difference is very noticeable especially as my Maxi is often driven with neither the 2nd or 3rd row of seats in it. Prior to doing any of this there was way more noise in the back.
Transitionpilot
Post by Transitionpilot »
Nice colour, don't think I've ever seen that in real life
Is the off set of the wheels ok, in the second pic it does look like the back wheels are almost level with the arch (instead of sat just inside)?
Useful pics of the inside of the door too, I really cba to put the last few bits of sound deadening inside the doors as it looks like a fiddly job!
juliang71
Post by juliang71 »
Thanks, yeah I think the colour is really nice. I've only seen a few myself.
The offset is fine and I think it's just the picture doing that, they don't poke out beyond the arch and they are just on the inside of the arch.
It's taken me an age to get this far but it's not my daily and often just sits for weeks in the garage. I've really quite enjoyed putting the insulation and what not in. I just need to get the rest of the trim back in and do the drivers door now!
Marius_M
Post by Marius_M »
POTTERINDIUMMK4 wrote: Sun May 04, 2025 7:55 pm Got to be the best colour by far 🤙
The name of the colour surely adds to that :)
Ukrutony
Post by Ukrutony »
Julian, I see that you are using 225/40 R18. What is the rim width? Maybe that has to do with the rubbing issue you experience when vehicle is loaded.
I actually thought that Caddy might take 225/45 R18 7J from Touran when Touran does, but have not seen anyone doing that yet. Then the outer diam of the wheel would be bigger, bigger chance of rubbing and speedo would be off probably, since (for me at least) with stock 205/50 6J R17 it is nearly spot on. However, I wonder what all the people with swampers with huge wheels do about it. Do they not care about speedo accuracy at all?
Never really planned to mod my Caddy until I found this forum
juliang71
Post by juliang71 »
Rim width is 8 and 225/40 R18 is the correct tire size. The speedo is pretty much spot on, it's a fraction of 1mph off according to those tire comparison sites compared to the standard tires that come on a Maxi Life, and using Google maps when driving seems to confirm that.
The car is in the garage for the winter now so unlikely I'll be looking at this again until spring time. I'm sure the lowering kit needs some tinkering, it has the centralizing plates ... however I did not fit the kit so I need to check this. But I also need to properly measure or at least see if the rear wheels are sitting in the middle of the arch or not.
As this could be a cause of the issue, I know hundreds of Caddy owners are running lowering kits so I like to think it just needs some fine tuning. I just want the rear to sit a little lower. Not a massive amount but be the same as the front. And again I've seen loads a lot lower than mine.
juliang71
Post by juliang71 »
A simple job that I've been meaning to sort for months now. The leaf spring bump stops were literally falling apart, no idea how much VW charge for these so just bought a pack of 4 from eBay for £10.88 delivered. Fitted this AM, best to use a bit of washing up liquid to help them on. Pliers underneath to pull it down as you need to get the rubber lug through the hole in the leaf spring.
