Be4ny13
Re: Silver Maxi Kombi - Not a Show Van
Post by Be4ny13 »
Not having seen anyone do this, and very little even discussing the idea, I got a hold of a mk4 gear surround and attempted a worlds first* by fitting the mk4 gear surround below a mk3 dashboard.
After a lot of cutting and plastic welding I've got it to fit nicely but still waiting on the coin tray to complete it and then cover it all in suede to match. I'll likely start a thread with more detail in the interior mods section once that's done.
*may not be a worlds first but I couldn't find anything (Update: I have now found someone who has done this on the forum back in 2019 but still not a common mod by any means)ImageImageImage
Sent from my Pixel 7 using Tapatalk
Ukrutony
Re: Maxi - Not a Show Van
Post by Ukrutony »
Be4ny13 wrote: Mon Sep 02, 2024 9:04 am Quick addition over the weekend to test out how well the vinyl from my sun visors works with trim fix. Wanted something to stop my air freshener rolling around the dash so cut out a panel to fill the dash storage with a hole for the tin to sit in and wrapped it. Holds very tight pushed into the dashboard so I've no worries about the whole piece flying outImage
Be4ny, would you by any chance still have the link to the plastic-textured wrap you used? It looks very similar to the actual dash, I like it :D
Never really planned to mod my Caddy until I found this forum
Be4ny13
Post by Be4ny13 »
Be4ny13
Post by Be4ny13 »
Trimmed, all parts fitted, and a new gear knob to finish it off ImageImageImageImage
Be4ny13
Post by Be4ny13 »
Having tried a few locations and switches from other models for moving the hazard switch I think I've finally settled on the best option and it's exactly where I started in the first place. Used a hazard switch from a polo 6C which looked to be the same size as the auto stop switch from the mk4 caddy and had a very similar button shape profile. Well I was half right. The actual connector and part that clips into the trim is identical but the actual button face was about 0.5mm bigger all round and sat flatter, with a bit of sanding and some filling behind the button to angle it to match the others I reckon this is the one. A little bit of fettling still needed to get it spot on but it's looking goodImageImage
Some real nice touches on this mate 🤘
Sent from my Pixel 9 Pro XL using Tapatalk
I'm also looking for some switches, just today put some red led push switches in but since seeing some of the OEM looking ones on Ali express I would much prefer them.... Just trying to find some that won't look out of place
Be4ny13
Post by Be4ny13 »
One hazard switch all filed down, adjusted to fit as best as possible, and wired in. Conveniently all the same pins and coloured wires so that was easy to do. Next step is to fill in the old switch hole and cover the dash Image
Be4ny13
Post by Be4ny13 »
The latest caddy projects haven't been all that exciting just servicing including timing belt, water pump, and all the boring stuff that we must do to keep our vans running but in between I have been sourcing bits to fit a PTC heater and over the weekend I got it all fitted. I haven't got any photos of this because it isn't that exciting but as I had the light switch panel out I decided to pull the trigger on a little project I'd been putting off for a while. This is a mk7 golf light switch and trim hacked about and made to fit into the caddy panel with the headlight adjusters and interior light level switches hidden. The golf switch has been gutted and the caddy light switch electrics installed as it doesn't operate the lights correctly and the caddy switch sits at a jaunty angle in the golf trim. Also I like the look of the new switch more. Recovered and installed the panel, now I've just got to finish blanking the hole in the golf light switch trim and paint itImageImageImageImageImage
Have you gone over it with faux leather? That looks really smart!
I may steal this mod
Be4ny13
Post by Be4ny13 »
Yes, it's a 4 way stretch vinyl. Have used it on my glove box too, has a really nice feel to it and easy to work with. Feel free to have a crack at it!
Be4ny13
Post by Be4ny13 »
Light switch trim complete, fitted and pretty happy with the result ImageImage
Looks great mate
Be4ny13
Post by Be4ny13 »
Haven't done much to the Caddy for a while but have fitted a new reverse camera as that stopped working and a bigger battery as the previous one would die over a couple of days. Thought it had a parasitic drain but can't find anything drawing excessive power so will just see how it goes. Jump to yesterday, I was bored, thought I'd have a crack at something I've been wanting to try for a while - DIY short shifter. Knocked the pin out of the selector arm and drilled a new hole approximately 15mm closer to the pivot. Cut threads into the hole and onto the pin and hey presto. Was surprisingly easy to do and felt good on a short drive down the road, may add another hole even closer as I think the throw could be reduced more. Wasn't thinking about photos whilst doing this so you only get after photos ImageImage
jakemcc97
Post by jakemcc97 »
Good idea on the short shifter!
Jake's Caddy Camper Build
Silver 2017 2.0 TDI Highline
