Page 23 of 25
Posted: Sat Jul 30, 2022 4:30 pm
by ToiletTFSI
That’s about as close as it gets! Was this a Mk5 golf designed ap setup?
Posted: Sat Jul 30, 2022 4:37 pm
by Giddy
Yes Golf mk5/6
Posted: Sat Jul 30, 2022 6:15 pm
by Handyandy
Them calipers look really nice πŸ‘Œas you say it's a pity you can't get them fitted before tatton which is just over a week away πŸ‘
Posted: Thu Jan 26, 2023 10:04 pm
by Linguritza
Just spent the night reading this thread. Great work man ! Very inspiring, also I love the attention to details that you give
Posted: Thu Jan 26, 2023 10:40 pm
by Nwcaddy
Van looks absolutely lovely!
Can i ask where/how you wired the 12v sockets into? Did you choose a constant live feed or an ignition live?
Cheers!
Posted: Sat Jan 28, 2023 9:31 am
by Giddy
Thank you. I've added an extra circuit to a fuse box under the steering wheel. There are some empty slots to chose from. Mine is wired to a permanent 12V.
This 'how to' will give you a lot of details https://www.caddy2k.com/forum/viewtopic.php?t=33096.
Posted: Mon Jan 30, 2023 11:32 am
by drwormy
Love the build! Especially the caliper colour!
Posted: Sat Mar 04, 2023 9:35 pm
by Dalecaddy
Just read through whole build. Nice work throughout mate 🍻
Posted: Sun Jul 16, 2023 1:52 pm
by Giddy
Only took me a year to get back to this ImageImageImage
Weld-on saddles from Retrofication welded to the axle and then the axle was powder coated.
RacingLine stud conversion done.
And finally fitted my not so big brake kit front and rear.
Posted: Sun Jul 16, 2023 3:54 pm
by Lister79
Some more quality mods . Looks superb mate.
Posted: Sun Jul 16, 2023 10:39 pm
by FishermansFriend
Lovely set up, and installed for Tatton Park this year. Did you use the Locktight on the studs?
Posted: Mon Jul 17, 2023 9:44 am
by Giddy
Thanks lads. Yes, I've used the Loctite.
Unfortunately won't be able to attend the Tatton Park show this year, as will be working abroad...
Posted: Fri Jul 21, 2023 8:04 am
by DW2207
Hi Giddy, I recently purchased the retrofication weld on saddle kit.
How do you find the setup up now over the shackle kit?
I went like you fully poly bush on the rears.
Maxi rear arb etc.
At the moment the rear axel sway is almost eliminated. Mine is set up on the highest setting mind you for practicality.
Do you have a side on shot of the rear wheels please and how they sit in the wheel arches buddy?
Thanks Dan
Posted: Fri Jul 21, 2023 4:47 pm
by Giddy
Hi Dan. I think Retrofication saddles add some height, around 5mm or so. I haven't measured the height before and after, but visually it looks a tiny bit higher to me than it was before with bolt-on kit. Not a problem, will readjust the hangers by one hole.
The wheels sit bang on in the middle. The reason for that is I've made a custom plates with 10mm offset to clamp the axle to the leaf springs. Mk4 leaf springs are slightly different to the previous generation with the dowel pin at the bottom, so I needed a custom plates regardless.
Posted: Sat Jul 22, 2023 7:55 pm
by Sabbunsingh
I love the mods on this van. Proper job
