Another bike van build
Baldspeed Racing
Re: Another bike van build
Post by Baldspeed Racing »
nice set up and sweet looking bike btw
@baldspeed on Insta
Transitionpilot
Post by Transitionpilot »
FortanaMK5 wrote: Sat Oct 18, 2025 8:39 am I can only dream of loading my bike up without pulling the front wheel out. Zero chance with modern XL enduro and DH bikes given the length of them 🤦🏼‍♂️
I prefer the proportions of the swb but practicality had to take priority (That probably means i'm turning into an old fart tho!)
I'm also pretty sure that it doesn't load in and out any quicker than if you have to take the wheel off :roll:
Transitionpilot
MatthijsA wrote: Sat Oct 18, 2025 8:21 pm Nice! I think i need to do some wood work for my own bike :)
The simplest way to do the front wheel is just two rails, similar to the back one but without the triangle upper part but I like to overcomplicate little tinkering projects to keep me occupied!
Transitionpilot
Got another couple of jobs ticked off the list lately, got all the thermoliner into the back - for some reason sticking this stuff down is nowhere near as fun as satisfying as doing dodomat...
had to take the bulkhead out for the 150000th time to get in behind the corners
Got all the way down to the bottom of the side panels
Transitionpilot
And done the back doors and the lower part of the side doors, the easiest way I found to do the barn doors was to use smaller pieces that are more manageable to wiggle into position without sticking in places you don't want them
Last edited by Transitionpilot on Mon Oct 20, 2025 9:00 pm, edited 1 time in total.
Transitionpilot
The only parts I haven't done yet with thermoliner are the upper side panels as i'm a bit stuck as how to attach ply in the recess. I want to put a 5mm panel into it and I've tried just using a baton down the centre rib to screw it too but the ends are a bit too flappy. So if anyone has got any ideas or can screenshot something from the how-to section that would be great. Needs to be a method that is tidy and takes into account the carpet thickness too!
Transitionpilot
Baldspeed Racing wrote: Mon Oct 20, 2025 7:39 am nice set up and sweet looking bike btw
Cheers mate, that bike has thrown me down some pretty big hills over the years - on and off of it!
Baldspeed Racing
Transitionpilot wrote: Mon Oct 20, 2025 11:41 am Cheers mate, that bike has thrown me down some pretty big hills over the years - on and off of it!
Hahahaha all a part of the riding as my old bike was the same. But then I think my new one will do at some point even though I've had some big saves on her so far.
@baldspeed on Insta
BigJohn_mk4
Post by BigJohn_mk4 »
Looks good, I like the idea of the bike mounts and Velcro straps, being in a swb I’ll need to take off the front wheel tho.
I’ll keep checking on this post and look to possibly post up my own too
Scotscad
Post by Scotscad »
Hi, i used aluminuim composite sheet to fill in my panels. I made a template from card and transfered to the acs then i bonded it on with tiger seal. Its easy to use and u can bend it to follow the curve of the van. I then carpeted over it, job done. Have sum pics of it on here in the build section on ‘gertrude’ thread when i showed him where id mounted my rear speakers. I also sound deadened the van before i stuck the acs on. Hope this helps.
FortanaMK5
Post by FortanaMK5 »
Transitionpilot wrote: Mon Oct 20, 2025 11:23 am I prefer the proportions of the swb but practicality had to take priority (That probably means i'm turning into an old fart tho!)
In my case it’s the other half’s daily as well as weekend bike transport. Parking challenges where she works rather than solely cosmetics were a major driver for getting the SWB. I think if the Maxi was an option we’d have been in the territory balancing whether we may as well get a SWB transporter.
mando
Post by mando »
Transitionpilot wrote:And then a coat of Waxoyl underseal on everywhere that doesn't have any factory stonechip stuff, leave it for 24hrs and it should be good to go
Great job looks super clean, I’ve been telling my self I’m going to this for last few years never around to it lolImage
jakemcc97
Post by jakemcc97 »
Transitionpilot wrote: Mon Oct 20, 2025 11:38 am The only parts I haven't done yet with thermoliner are the upper side panels as i'm a bit stuck as how to attach ply in the recess. I want to put a 5mm panel into it and I've tried just using a baton down the centre rib to screw it too but the ends are a bit too flappy. So if anyone has got any ideas or can screenshot something from the how-to section that would be great. Needs to be a method that is tidy and takes into account the carpet thickness too!
Good progress!
I'm also stuck on that bit. Current plan is to cut some 9mm ply to fit then use sealant to bond it into the recess. Then just carpet over the whole lot.
Jake's Caddy Camper Build
Silver 2017 2.0 TDI Highline
Transitionpilot
mando wrote: Fri Oct 24, 2025 9:21 pm Great job looks super clean, I’ve been telling my self I’m going to this for last few years never around to it lolImage
tbh I only did it because it was already fairly clean underneath, it probably only took an hour or so to brush the waxoyl on.
Transitionpilot
jakemcc97 wrote: Sat Oct 25, 2025 12:05 am Good progress!
I still haven't figured this out yet, I want the ply panels to be a different colour carpet from the walls. I'm swaying towards putting a 3mm strip of ply behind the lip and then screwing through the lip and into that to give it something to bite into. Would help if I could make up my mind about which colours to do the carpet too!
