Brooneye's build
brooneye
Re: Brooneye's build
Post by brooneye »
[mention]Giddy [/mention] it’s for a display unit
[mention]Rickytango [/mention] thanks for taking the time to read, it’s well documented on the forum once you get full access you’ll be able to see the posts
brooneye
Post by brooneye »
Stripped, cleaned the rear floor and added some sound deadening.
Just got to do the arches and the sides and then carpet
Aronfields
Post by Aronfields »
Brilliant build hoping to put a newer dash and golf r wheel into mine in the next few weeks
brooneye
Post by brooneye »
[mention]Aronfields [/mention] thanks for taking the time to read through.
The dash and mfsw are well worth the time and effort to do
Aronfields
I have a mk7 golf at work that's damaged I might play about with the dash and mfsw in it to see if I can get it all working I have odis online vcds and I do car keys for a living so the immo side/coding shouldn't be an issue if I can work it out
brooneye
Post by brooneye »
The dash won’t work, it would have to be a touran one. There’s a little bit more involved on the mfsw side such as modules but if you have a search it’ll point you in the right direction
.danny
Post by .danny »
Nice clean van mate, are you from the birtley area? Sure iv seen this about
brooneye
Post by brooneye »
Cheers [mention].danny [/mention] I work in Birtley. Take it you must be local
brooneye
Brooneye's build
Post by brooneye »
Been busy over the last few months installing air ride and all the relevant upgrades.
I went for the airlift fonts, with the Intermotiv rear set up controlled by the 3P. Ran all the lines through the interior but totally forgot to take pictures of the install
While I was at it I upgraded to the 55mm hubs with a set of gti callipers and disks
Job for the weekend is to re do the carpet in the rear and if it’s delivered the second compressor harness, for some reason forgot to order it and a good clean
Sean1066
Post by Sean1066 »
That air ride looks awesome.
So low its on the floor 👌
Caddy maxi 3.2 VR6 EX BG
My build thread
R22LRM
Post by R22LRM »
Seriously low there mate, looking awesome
R22LRM
Mk5 Tfsi powered
Lister79
Post by Lister79 »
Looking good, very low. Have you still got the arch liners installed?
Pepsi
Post by Pepsi »
How low can you go?...
Well... to the floor actually.
Looks mint
brooneye
Post by brooneye »
Thanks guys, it’s seriously low but that’s all part of the fun.
[mention]Lister79 [/mention] arch liners are back in with a little trimming
Ripley55
Post by Ripley55 »
Hi @brooneye
Are the wheels OEM VW ? what sizes/ET/Width/Tyres etc mate ? :?:
