The original set up had Powerflex Purple Bushes, the 4WD rear end will be fitted with Powerflex Black Series as it's going to be used on track more when it's finished.the long one wrote: ↑Fri Nov 10, 2017 6:57 pm As I can’t see the pictures at the start did you fit black or purple rear bushes ?
SRS Automotive 300+bhp BKD #Racevan - Ex Darkside Developments
Mayor West
Re: SRS Automotive 300+bhp BKD #Racevan - Ex Darkside Developments
the long one
I was thinking of fitting black bushes to the maxi but unsure what they would be like . Also replacing the gearbox any suggestions like what you had but it’s a bls motor thanks in advance
Mayor West
Iv'e not driven on the road with black bushes but will be shortly, I can't see it being massively different to the purple ones but I could be wrong, I'll soon find out anyway. lolthe long one wrote: ↑Mon Nov 13, 2017 7:41 pm I was thinking of fitting black bushes to the maxi but unsure what they would be like . Also replacing the gearbox any suggestions like what you had but it’s a bls motor thanks in advance
If you're swapping the gearbox you want one of these really:
http://www.ebay.co.uk/itm/322872335230
Far more reliable than the 5 speed and obviously better on motorways with the extra gear.
Crowncustoms
Can't wait to see the finished result, keep up the good work srs and darkside
Sent from my STF-L09 using Tapatalk
the long one
As my clutch is on its way out I will be looking to do this in January so will be giving you a call
Mayor West
I can't wait either, it's away at the minute having the 4wd conversion at the minute, hopefully it will be back before xmas so we can get the big power engine fitted.Crowncustoms wrote: ↑Mon Nov 27, 2017 12:50 am Can't wait to see the finished result, keep up the good work srs and darkside
Mayor West
No worries, I look forward to your callthe long one wrote: ↑Mon Nov 27, 2017 5:20 pm As my clutch is on its way out I will be looking to do this in January so will be giving you a call![]()
Mayor West
The Caddy is away having the 4wd rear end sorted at Slide Motorsport in West Yorkshire so while it's there we thought we may as well get some parts ready for it's return.
We chose to powdercoat the parts in the same colours as out logo which I think has turned out really well.
Rear end parts to follow....
slipperjake
Proper! What rear brake set up you going to use?
- R22LRM
One serious bit of kit your gonna have on your hands
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Mayor West
MK5 R32 310mm rear brakes, I'll get some more pictures on asap. It's not quote built up yet so I'll wait until we have everything here for it.slipperjake wrote: ↑Fri Dec 22, 2017 3:49 pm Proper! What rear brake set up you going to use?
the long one
Tomorrow will call you about gearbox thanks
the long one
Gearbox finially finished all ok
Stefan is a top man
Stefan is a top man
Mayor West
Good to hear it's all in and sorted now
"Stefan is a top man" - I agree
the long one
Have you got this back yet ?
