Airbags
Sean1066
Airbags
Post by Sean1066 »
I took my seats out today to change them over to Audi A3 S line.
I found out that I don’t have airbags in the the seats.
The Audi seats have airbags and also seatbelt sensors.
should I just leave them unplugged and everything will be ok
Should I get someone to wire them in. Is it a lot of work to wire them in because of all the sensors.
Caddy maxi 3.2 VR6 EX BG
My build thread
Sean1066
Re: Airbags
Post by Sean1066 »
Passenger side
Drivers side
My build thread
walnut417
Re: Airbags
Post by walnut417 »
I switched seats in my 07 Caddy with Golf seats and tied off the wiring for the airbags. You should have a sensor for your seatbelt stalks though?
r1lea
Re: Airbags
Post by r1lea »
To wire in the seat airbags is a big job, as well as the looms you’d need the correct airbag controllers etc and they would need to be compatible with your existing modules etc
Just leave them is my advise, the caddy comes without them so no required etc
r33sxo
Re: Airbags
Post by r33sxo »
You should be completely okay mate. I removed standard caddy seats out of my 2005 and replaced them with 2015 A3 Sline seats. That had plugs/connectors on it and I never plugged them into anything.ImageImage
Candy White Caddy - R33S XO
